Air conditioner is working sometimes
54,000 MILES • 6 CYL • 2WD • AUTOMATIC
JERRY DURO
  • 16 POSTS
Checking the system at proper temperature and humidity I get 95 on the low side and 100 high side. When it is working as it is now I get thirty degrees from the duct reading. It has been running for an hour now. The low side meter is got a little vibrating going on.
According to what I know it should not be putting out cold air with these readings. But, like I said it might not come on tomorrow or it might. This morning it came on and these are the readings.
Jul 11, 2017 at 1:26 AM
HMAC300
  • 48,601 POSTS
This kind of sounds like a bad compressor but being auto temperature control you should have a mechanic scan for codes first. If compressor is bad system needs to be flushed. See link.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Jul 11, 2017 at 2:31 AM
JERRY DURO
  • 16 POSTS
One final question. I increased the cabin temperature to 90 and the compressor did not shutdown. Could there be a second problem?
Jul 11, 2017 at 3:54 AM
HMAC300
  • 48,601 POSTS
Well there could be these have auto temperature control and can only be diagnosed with a scanner that a mechanic uses. so that should be done as well, but if compressor is working with the pressures you gave sounds like it is shot.
Jul 11, 2017 at 5:32 AM
JERRY DURO
  • 16 POSTS
Thank you for your help.
Jul 11, 2017 at 5:48 AM
HMAC300
  • 48,601 POSTS
Make sure that the compressor runs before replacing it. it may not be running like the clutch is not engaging.
Jul 11, 2017 at 7:57 AM
