I would like to disable the blend door motor
124,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
ARNOLD KNUTSEN
How can I disable the blend door motor? I cannot do it with a fuse, but need to remove a connector. how can I locate that connector ? Is it accessible if I remove the glove box and go through the door ?
Oct 18, 2016 at 5:20 AM
JIS001
  • 3,412 POSTS
The only way to access it is to pull the dashboard out the vehicle.
Oct 18, 2016 at 8:49 AM
ARNOLD KNUTSEN
Think I will just let that blend door run until it wears out. I do not need it where I live as heater is not needed and air conditioner is frosty cold! Thank you !
Oct 18, 2016 at 8:50 PM
