Air conditioner fuse box
58,000 MILES • 4 CYL • AUTOMATIC
WOMAN'SCAR
Air conditioner blowing warm air. Dealer states new fuse box required at over $500.00. I looked at cost of fuse box online, and they are not expensive-compressor is fine, full of Freon? Found no other problem except the wiring into fuse box. Can the wiring be fixed without replacing the entire fuse box? Help!
Jun 26, 2018 at 1:13 AM
AL514
  • 5,700 POSTS
it depends on if the fuse box is full of corrosion, it happens. If power is not being distributed correctly you will have all kinds of problems, no cool air is probably just the start of issues. The expensive part of that replacing the fuse box is all the work it requires.
Jun 26, 2018 at 3:47 AM
