Air conditioner electrical problem
180,000 MILES • V6 • 2WD • AUTOMATIC
BRIAN WILLIAMS
  • 7 POSTS
I replaced the blower motor two years ago and everything was working fine then it just stopped blowing any air on every setting. I took it to a mechanic and they did a free A/C check. They said the blower motor is fine, but would need to do an electrical diagnosis to figure out the problem. The wires under my glove box (red and black) both have power running through them. The ground wire isn't supposed to be reading any power is what they told me. What could be the problem? Also I have very little knowledge of this stuff so please try to explain it the most basic way possible. Thanks.
May 29, 2019 at 9:14 AM
Good evening,
The most common cause is the blower resistor. If it has failed, it will not ground the blower motor.
1. Disconnect and isolate the negative battery cable.
2. Remove the glove box.
3. Disengage the wire harness connector locking tab and disconnect the wire harness connector (1) from the blower motor resistor (2).
4. Remove the two screws (3) that secure the blower motor resistor to the HVAC housing (4).
5. Remove the blower motor resistor from the HVAC housing.
May 29, 2019 at 9:53 AM
D6SPAN
  • 58 POSTS
Hi Brian! I've attached a close up image of what wires should be going into and coming out of your blower motor. From this information, we see that the wires are dark blue (DB) and dark blue with a yellow stripe (DB/YL). On the regular image, you can trace back that dark blue wire and see that it gets power from the Blower Motor Relay when it it energized.
So the DB wire should have power when the blower motor is supposed to be on.
Now, the Dark Blue and Yellow wire may not have zero volts because it doesn't go directly to a ground, it goes to the blower motor resistor.
So, your first step would be to go directly to your blower motor and check for voltage on the dark blue wire, with the blowers on. Then check for voltage on the dark blue and yellow wire but see if it changes when you switch between high, med-hi, med-low, and low.
If you have voltage on the dark blue wire, then it is getting power, which is good. If there isn't power on the dark blue and yellow wire, then it could be your resistor, but let's not jump too far ahead, I'm also going to add links to some articles that will be helpful. Keep track of what you find so you can reference it later.
I think the latter half of this article on trouble shooting an AC system will be helpful to you, or at least the last half since you have had a mechanic do a free AC check.
This one is about how to test wiring.
And just one more, for good measure, is a troubleshooting guide for what to do when you are not getting air coming out of your vents.
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
May 29, 2019 at 9:57 AM
BRIAN WILLIAMS
  • 7 POSTS
Okay, thanks I will look at that stuff and see what I can figure out.
May 29, 2019 at 10:00 AM
Keep us updated.
May 29, 2019 at 10:07 AM
BRIAN WILLIAMS
  • 7 POSTS
I have bought the resistor and the housing/connector thing and will be putting it on at some point this weekend. I hope it fixes my problem.
May 31, 2019 at 1:28 AM
Keep us updated.
May 31, 2019 at 5:32 AM
BRIAN WILLIAMS
  • 7 POSTS
Replaced the resistor and harness. Still no air.
Jun 1, 2019 at 6:26 AM
Did you verify the powers as I suggested way back in the beginning?
Jun 1, 2019 at 6:29 AM
BRIAN WILLIAMS
  • 7 POSTS
Yes, I had an electrical gauge.
Jun 1, 2019 at 6:36 AM
How many volts did you have on both sides of the fuses?
Jun 1, 2019 at 6:38 AM
BRIAN WILLIAMS
  • 7 POSTS
I had a guy doing it for me I think he said it was 12.
Okay, good.
Now he needs to check for power to the resistor itself as in the diagram.
Jun 1, 2019 at 6:41 AM
BRIAN WILLIAMS
  • 7 POSTS
Okay, well I think I'm just going to pay for the electrical diagnosis because this is way above my level of knowledge.
Jun 1, 2019 at 6:57 AM
Okay, Keep me updated.
Jun 1, 2019 at 7:00 AM
