Air conditioner blowing hot air
218,000 MILES
FORGIVENMH41
Okay, on my wife's vehicle listed above the water pump went out so I changed that and the thermostat. then the radiator had a crack I noticed so I went back and replaced that. then when I started it up the A/C was blowing real cold air for about 2 minutes then started blowing hot air, but before all the work it was cold. what would cause this?
Jun 8, 2020 at 5:41 PM
Good morning,
You may have a leak in the system and the freon leaked out.
https://www.2carpros.com/articles/air-conditioner-leak-detection
Does the compressor engage when you turn it on?
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Do you have a set of gauges that will tell the high and low side pressures?
Jun 8, 2020 at 7:30 PM
