Air Conditioner
90,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
MCAVINEE
  • 69 POSTS
Do you have a diagram of the fuse box where I can make sure I find the correct air conditioner clutch relay? Thanks
Aug 24, 2016 at 8:23 PM
WRENCHTECH
  • 20,760 POSTS
This truck doesn't use and external relay for the compressor. The controls are internal to the TIPM which is the fuse box. If that is determined to be the problem, the whole fuse box has to be changed.
Aug 24, 2016 at 8:59 PM
