Air conditioner if I turn the fan on high, the A/C turns off?
136,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
SHERILYN FRANKLIN
  • 90 POSTS
my A/C only comes on when I turn the fan on but, if I turn the fan on high the A/C goes off.
Jul 9, 2024 at 12:54 PM
CANNON1349
  • 861 POSTS
This sounds like a Climate Control Head issue. The A/C should only come with the fan yes, but there may be a problem with the logic board or memory in the unit. There could potentially be an issue with the controls, but it is hard to rule out. Do you have a scan tool of any kind? I would scan the CAN system for any codes, we would be looking for body codes or climate control module codes stored in the memory. Please see our guide below on scanning the CAN system.
Hope this helps,
William
Jul 10, 2024 at 9:37 AM
SHERILYN FRANKLIN
  • 90 POSTS
Thank you!
Jul 10, 2024 at 10:02 AM
SHERILYN FRANKLIN
  • 90 POSTS
That scanner is out of my price range, can you suggest a least expensive scanner??
Jul 10, 2024 at 1:24 PM
CANNON1349
  • 861 POSTS
To read body codes / HVAC module codes, you may need a better scanner. I found a scanner on Amazon that may do the trick:
https://www.amazon.com/Creader-CRP123-Transmission-Automotive-Diagnostic/dp/B01HNO5PLY/ref=asc_df_B01HNO5PLY/?tag=hyprod-20&linkCode=df0&hvadid=692875362841&hvpos=&hvnetw=g&hvrand=16547413944348374471&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9009598&hvtargid=pla-2281435178618&psc=1&mcid=9c6d5a2ccafa36e7b4a34ee05543312a&hvocijid=16547413944348374471-B01HNO5PLY-&hvexpln=73&gad_source=1
You may also need to search for scanners that can read "U" codes. This scanner I found is just an example. Otherwise, you can stop by any autoparts store and their scanner should be able to read it for you.
Thanks,
William
Jul 12, 2024 at 12:08 PM
SHERILYN FRANKLIN
  • 90 POSTS
Why does my radiator warning light come on when its full of antifreeze? When I turn my car off and back on it goes off, it seems to come on intermittently.
Jul 13, 2024 at 6:06 AM
SHERILYN FRANKLIN
  • 90 POSTS
Did you see my new question??
Jul 15, 2024 at 2:27 AM
CANNON1349
  • 861 POSTS
Sorry for the delay. I am not familiar with a "radiator warning" light, can you send us a photo or description of what you mean? If it's regarding coolant level, make sure you have the right amount of coolant, and if you do, the sensor could have an issue. There also may be a light for coolant temperature, some cars it shows up as blue on startup, and once the car is warmed up enough it will turn off.
Let us know,
William
Jul 15, 2024 at 8:57 AM
SHERILYN FRANKLIN
  • 90 POSTS
Can you send me a pic of where the radiator plug is located? the video doesn't let me see where is, I'm going to flush and fill my radiator but I can't find the plug.
Jul 15, 2024 at 2:34 PM
CANNON1349
  • 861 POSTS
According to the diagram, it looks like the drain is on the passenger side of the radiator and will require a flathead screwdriver type tool to unscrew out. I attached a photo from the repair procedure, nothing should be in the way of you getting the screw out.
Hope this helps,
William
Jul 16, 2024 at 12:30 PM
SHERILYN FRANKLIN
  • 90 POSTS
I saw this pic already I'll try to find it tomorrow.
Jul 16, 2024 at 1:42 PM
  • 55,721 POSTS
any luck?
Jul 18, 2024 at 3:51 AM
SHERILYN FRANKLIN
  • 90 POSTS
I "think" I may have found it, I will look again tommorrow.
Jul 18, 2024 at 11:50 AM
SHERILYN FRANKLIN
  • 90 POSTS
Is it on the drivers side??
Jul 18, 2024 at 11:51 AM
CANNON1349
  • 861 POSTS
There should be a protrusion from the radiator facing towards the wheel. Not towards the engine. From the diagram I have it looks like it may be on the passenger side.
William
Jul 18, 2024 at 11:56 AM
SHERILYN FRANKLIN
  • 90 POSTS
Okay, I'll take a look tomorrow.
Jul 18, 2024 at 12:07 PM
SHERILYN FRANKLIN
  • 90 POSTS
This is what mine looks like also a picture underneath it. It looks nothing like the pic you sent there is nothing on it where I can unscrew a plug.
Jul 21, 2024 at 3:01 PM
CANNON1349
  • 861 POSTS
Judging from the diagram the drain is on the side of the unit. It will require a tool to be put inside it so you may see a molded piece with an indentation.
William
Jul 22, 2024 at 9:52 PM
SHERILYN FRANKLIN
  • 90 POSTS
What kind of tool??
Jul 23, 2024 at 2:22 AM
SHERILYN FRANKLIN
  • 90 POSTS
That second pic I showed you was the bottom not the side.
Jul 23, 2024 at 2:23 AM
CANNON1349
  • 861 POSTS
Yes, I saw that it was the bottom. Try looking on the sides of the radiator. You should be able to use a flathead screwdriver to turn the drain.
William
Jul 23, 2024 at 2:26 AM
SHERILYN FRANKLIN
  • 90 POSTS
Okay, I'll let you know when I get around to it.
Thanks
Jul 23, 2024 at 8:40 AM
SHERILYN FRANKLIN
  • 90 POSTS
I finally found the drain plug! I drained the fluid and then put distilled water into the reservoir after that I added antifreeze. I checked yesterday and I had no antifreeze in the reservoir! What did I do wrong??
Jul 31, 2024 at 5:14 PM
CANNON1349
  • 861 POSTS
Sounds like you may have measured it incorrectly. Is the reservoir a pressurized bottle? If so, then this is the only place to add coolant. Also, be sure to mix the coolant before adding it to the vehicle, it will not mix together equally inside the system. I say make more of the mix and add while the car is running, turn the heat on, and wait for the level to drop after the thermostat opens. Then check your level and turn off the car, wait an hour and see where the level is again.
Let us know,
William
Aug 1, 2024 at 9:52 PM
SHERILYN FRANKLIN
  • 90 POSTS
Thanks!
Aug 2, 2024 at 7:48 AM
CANNON1349
  • 861 POSTS
No problem. Please don't hesitate to ask us for assistance, we are here to help. Thank you for using 2CarPros!
William
Aug 2, 2024 at 10:29 AM
SHERILYN FRANKLIN
  • 90 POSTS
I replaced my air intake sensor and I'm still getting dash warnings and code p0013.
Aug 13, 2024 at 2:01 PM
  • 55,721 POSTS
Sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
Aug 14, 2024 at 3:01 AM
