Air conditioner does not blow out cold air
147,000 MILES • 4 CYL • 2WD • AUTOMATIC
ANGELINAKESLAR
My heater works fine, but the AC will not blow out cold air. It just circulates the outside air instead of getting cold. Do I need to recharge my AC or could there be a leak?
Jun 8, 2019 at 1:25 AM
You could have a leak but it does sound like the system is low. You can refer to the guides below on how to recharge the system and see if you get functionality back. If you do, it may not last long. If the system empties again, then you will need to pull it down into a vacuum using a pump that you can rent from a parts store. This will test to see if the system can hold a vacuum. If it cannot, then you have a leak and you will need to inspect the system to try and find it.
However, I would start with trying to recharge it and see if that takes care of the issue. If it does hopefully it will last a while so you don't need to take immediate action however, I would start planning for it because a leak will only get worse.
Please let me know if you need more information. Thanks
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Jun 8, 2019 at 5:14 AM
