Disconnected the battery Now air won’t blow cold. This light comes on blinks three times then goes off.
Jun 19, 2019 at 7:58 AM
✓Experienced Mechanic
Good afternoon,
Why did you disconnect the battery?
Was the AC working prior to this?
I attached a wiring diagram for you to view. Check the two fuses listed for power on both sides with a test light or voltmeter.
Image (Click to enlarge)
Jun 19, 2019 at 8:08 AM
LISAKAYE
MEMBER
Replaced the starter after that the battery wasn’t charged enough to crank. So has to charge the battery and it started with no issues. Yes, the air conditioned worked prior to this. Just after disconnect the battery and connected back the air blows but not cold.
Jun 19, 2019 at 8:44 AM
Does the compressor engage?
Jun 19, 2019 at 8:49 AM
LISAKAYE
MEMBER
No.
Jun 19, 2019 at 9:04 AM
Do you have a scan tool to check for codes in the A/C system?
Jun 19, 2019 at 9:08 AM
LISAKAYE
MEMBER
On the A/C compressor clutch relay 87 is hot. do I jump power from there to 30 to make clutch engage?
Jun 19, 2019 at 9:16 AM
LISAKAYE
MEMBER
Sorry my husband corrected me on that 30 is hot not 87.
Jun 19, 2019 at 9:18 AM
30 is the hot wire and 87 goes to the compressor. You can jump it with a wire to test to see if the compressor works.
The control side, 86 and 85 are what controls the relay.
Jun 19, 2019 at 9:26 AM
LISAKAYE
MEMBER
When the jumper is put between the 2 it activates and shuts off the motor immediately.
Jun 19, 2019 at 9:35 AM
Between which 2 terminals?
Jun 19, 2019 at 9:47 AM
LISAKAYE
MEMBER
30 and 87.
Jun 19, 2019 at 10:16 AM
LISAKAYE
MEMBER
Could the battery have something to do with this? Because after we change the starter it would only crank in neutral. Then my husband charge the battery and and it crank in park like normal. Prior to this our air was putting out cold.It was when we hook battery back up is when it wouldn’t blow cold. So not sure if battery might not strong enough so the compressor can't kick on
Jun 19, 2019 at 10:22 AM
If the motor shuts off then maybe the compressor is locked up.
If you jump 30 and 87 with the key on and engine off can you hear the compressor engage?
