Air Conditioner
90,000 MILES • 3.3L • 4 CYL • FWD • AUTOMATIC
MCAVINEE
  • 69 POSTS
Our air conditioner was working fine this morning and by afternoon was blowing hot air. With the hood up I cannot hear the compressor kicking on. Checked the guage and tried adding charge and the gauge is all the way to the right in red. Any ideas? Thanks
Aug 2, 2016 at 10:03 AM
SATURNTECH9
  • 30,869 POSTS
You could be overcharged now because the charge could have been correct before you started adding charge. So was the radiator and air conditioner condenser fans running with the air conditioner on?
Aug 2, 2016 at 10:22 AM
MCAVINEE
  • 69 POSTS
No, I noticed that the radiator fan was not running. I checked the fuses.
Aug 2, 2016 at 11:39 AM
SATURNTECH9
  • 30,869 POSTS
Don't you have two fans one for the radiator and one for the condenser?
Aug 2, 2016 at 11:42 AM
SATURNTECH9
  • 30,869 POSTS
If you do not get enough air pulled through the air conditioner wont work right. Was the air conditioner working when driving high speeds before you tried adding air conditioner charge?
Aug 2, 2016 at 11:43 AM
MCAVINEE
  • 69 POSTS
Yes, I was driving down the highway all morning and it was cool. By Afternoon it was all hot air. The fans should kick on when I turn off the engine to cool things down correct?
Aug 2, 2016 at 11:49 AM
SATURNTECH9
  • 30,869 POSTS
The fans do not always stay on after the engine is turned off. It all depends on the engine coolant temperature when the engine is turned off.
Aug 2, 2016 at 12:19 PM
MCAVINEE
  • 69 POSTS
I cannot hear the compressor kick on either. So strange, so sudden. Thanks for your information.
Aug 2, 2016 at 7:33 PM
  • 55,658 POSTS
If I may, I would do a vacuum down and recharge of the system to remove any contamination. If you have excessive moisture it will cause the pressures to go way up.
Here is a guide to help you
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Best, Ken
Aug 10, 2016 at 4:30 AM
