Air conditioner takes between five to seven minutes to blow cold air
104,400 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
CPALMER305
This problem only is on the first time I crank my car. It takes 5 -7 minutes for the air conditioner to get cold. Then it just "turns on" and the air is very cold. For the rest of the day it works fine. But the next day only on the first crank/drive it just blows outside temperature for first few minutes.
Jul 21, 2021 at 2:29 AM
SQM
  • 6,383 POSTS
Is this symptom just started to happen or has it been going on for sometime?
First of all you should check to see if you have enough refrigerant in the A/C system.
Sometimes the A/C does not perform as well it should if the system is undercharged.
Here is a helpful article of how to check and add Freon:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
https://www.2carpros.com/articles/air-conditioner-leak-detection
https://youtu.be/4UjfQKvrB6Y
Please let me know what you find out.
Jul 22, 2021 at 3:43 AM
