air conditioner is blowing out warm air ?
75,000 MILES • 4 CYL • 4WD • AUTOMATIC
JAILCOPJOE
When it's hot out and humid the air conditioner is blowing out warm air if it is cool out the air conditioner is blowing out cold air.
Jun 7, 2021 at 6:56 AM
This is typical when the Freon is low. Here is a guide that will help with testing pressures and finding out if there is a leak. Let us know what the pressures are and we can go from there.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
If there is no leak and it holds a vacuum, then use this guide to fill the system:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Below you will find a chart that helps with what pressures should be based on ambient temperature. Let us know what you find and we can go from there. Thanks
Jun 8, 2021 at 8:57 AM
