air condition blows hot
2012 NISSAN MURANO
179,000 MILES
SHARON K BLAKELY
A/C blows hot. try adding Freon that did not work.
Jun 6, 2020 at 6:06 AM
Good evening,
Does the compressor come on when you turn the A/C on?
Do you have a set of gauges that you can give me the high and low side readings both with the engine off and running?
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
When you command heat and A/C can you hear the blend door moving in the dash?
Jun 6, 2020 at 8:04 AM
