A/C not blowing cold air?
210,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
HOLOCENE
A/C was not cold. I tried Freon but the gauge was beyond max in red range to see mechanic. I replaced very dirty cabin filter. A/C worked for a few minutes then air temperature. Compressor clicks as coming on the off I verified the A/C relay and fuses were good. A/C was working slightly until I fixed it. The air actuator gives hot when turned to heat but just blows air temperature when turned to cold.
Jul 22, 2024 at 10:41 AM
  • 55,694 POSTS
The fact that the gauge was in the red means you have too much refrigerant in the system. Here is a video to help you get the correct amount of refrigerant levels:
https://youtu.be/4EqdrBVb0sY?si=hVHuldYY0kAas1bt
Please go over this guide and get back to us.
Jul 23, 2024 at 3:06 AM
