Air-con fan motor making loud noise, how do I expose it or replace it.
92,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
TOROVIEJO1979
  • 16 POSTS
A piece of plastic tube fell into the air con vent and now the fan motor makes a loud noise when you turn on the fan. It will subside after a while but will continue again when you make a turn or come to a stop! Where do I locate the fan motor and how do I get in there to remove this plastic?
Aug 9, 2014 at 1:17 AM
HMAC300
  • 48,601 POSTS
take the fan motor out and remove the piece of plastic
Aug 9, 2014 at 3:00 AM
JDL
  • 16,098 POSTS
Just to add, looking under the hood, passenger side rear, can you see the blower motor? If not, you will have to follow some cut lines, like gmac says.
My info says you may have to remove coolant recovery reservoir and vcm.
I wasn't trying to butt in, I just happened to be looking up info on this vehicle. Have a good day.
Aug 9, 2014 at 4:12 AM
TOROVIEJO1979
  • 16 POSTS
Thanks, your answer is very helpful. I have located the fan, just where you said it was.
Aug 9, 2014 at 9:03 AM
TOROVIEJO1979
  • 16 POSTS
You are a genius and didn't know it.
Aug 9, 2014 at 9:07 AM
JDL
  • 16,098 POSTS
Hope you get it going your way.
Aug 10, 2014 at 3:02 AM
TOROVIEJO1979
  • 16 POSTS
JDL, your advise is very helpful. Thanks.
Aug 10, 2014 at 7:59 AM
