Air conditioner compressor rattle noise
75,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
JOE HAWKINS
The air conditioner compressor is making a rattling noise due to the metal hitting the outer casing on the bearing when it spins. Is there any way to fix the problem without having to buy a whole new unit?
Feb 26, 2018 at 10:05 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I assume you are saying it is internal, so in order to answer that question it appears that you would have to take the compressor apart and see what is wrong and see if a new part is available.
Feb 26, 2018 at 11:24 PM
JOE HAWKINS
Thanks for the answer. It is hard to explain but a ring shaped piece of metal is hitting the outer piece of metal when the belt is spinning. I have attached a photo with circles around the two metals that make contact.
Feb 27, 2018 at 12:01 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
that exterior clutch assembly should come off, then inspect it real good to figure out what is bent or whatever.
The clutch assembly usually comes as one entire assembly but I am sure somewhere, someone has the individual parts and might sell them.
I would start by checking the manufacturer of that compressor and checking out what is available.
Feb 27, 2018 at 1:16 AM
JOE HAWKINS
Okay, thank you for the help!
Feb 27, 2018 at 1:33 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You are welcome.
Feb 27, 2018 at 1:55 AM
