Air compressor/clutch noise
100,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
NMACFAYDEN
Air conditioning was working and the clutch was cycling on and off normally. Now, when air conditioning button is depressed, the clutch engages but makes a loud noise which changes with rpm of engine. Air conditioning blows cool but not really cold air. Compressor clutch does disengage when air condition is turned off.
Could it be the relay or pressure switch?
Please advise, thanks
Neil
Jul 4, 2018 at 12:46 AM
Good morning Neil.
The fact that the AC compressor is making noise is not good. It is either the clutch bearing or the internals in the compressor. This noise will be terminal over time.
No, it is not the pressure switch or relay. It sounds like it is the clutch seized at the pulley. And will not release.
It looks like you will need to replace the compressor, dryer and expansion valve.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Jul 4, 2018 at 1:43 AM
NMACFAYDEN
Thank you for your response but, the fact that the clutch does disengage when A/C turned off would suggest clutch is not stock, would it not?
Jul 4, 2018 at 8:29 AM
