Does my car have an Air Cabin Filter?
80,000 MILES
BUCKY101
I have a musty smell coming from the AC/heat and I'm told that North American Civics (2000) don't come with a air cabin filter as opposed to European models which do. Why did they do that and how do I treat the musty smell?
Jul 29, 2021 at 4:32 AM
You are correct that a 2000 Honda does not have a filter but the 2001 did so if this was a late build vehicle then you may want to check as they sometimes make changes before the actual module year change.
Here is a guide that helps with this:
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter
Here is a video that will give step by step instructions on a 2001 Civic:
https://youtu.be/gNPWN3hbkg0
However, even if your vehicle does not come with one, I attached the info from the manual that talks about how to treat this smell.
Please run through this info and let us know what you find.
Thanks
Jul 29, 2021 at 11:18 AM
