Air cabin filter
105,000 MILES
EMILO MORENO
Does my vehicle have an air cabin filter? As I could not find it and I bought one from watching your video which stated it did have one.
Jun 12, 2016 at 10:29 AM
  • 31,937 POSTS
I checked with Mitchell 1 data base and it says that there is no cabin air filter on this model.
Jun 12, 2016 at 11:29 AM
RYAN L
  • 273 POSTS
Basically GM changed it somewhere in that year range. It is pretty tough to tell when they did it because we come across those trucks all the time and some of them have ACF and some do not. So if it was not where it was in the video yours does not have an ACF.
Jun 13, 2016 at 9:24 AM
DBACKDON
How do you access the cabin air filter?
Feb 12, 2019 at 4:20 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
your vehicle is not equipped with a cabin air filter unless an aftermarket filter was installed.
NIGELSNIPE
V8 four wheel drive automatic.
How to find and change the cabin air filter?
JETSA
  • 117 POSTS
I do not think the 1998 models had cabin air filters. As a matter of fact I know they do not.
DORA S
how do i change the cabin air filter on a 1996 two door chevy tahoe
PROTECH1980
  • 901 POSTS
Some of these cars do not have one but if it does this video will help you change it.
https://youtu.be/Z1IPPJU68KA
Please let us know if you need anything else to get the problem fixed. Cheers
JENEFF
Is there a cabin filter for the a/c in a 97 Tahoe? If so where and how do I change it.
too early for a cabin air filter.
JMENEES
i have removed the kick plate held by the 3 screws and there is no visible filters. all that is visible is solid molded black plastic. there are no openings and no other screws to remove. how do i change the filters on my 03 Tahoe?
  • 110,248 POSTS
If you have one it will be under the hood near the cowl. Have you checked there?
2CP-ARCHIVES
  • 4,540 POSTS
how to change cabin air filter
his Article has been updated by bulletin #PIT3330, dated December 22, 2004.
Condition/Concern:
A customer may inquire about the availability of the passenger compartment air filter.
Recommendation/Instructions:
Starting in 2003 model year, the passenger compartment air filter is no longer available as a factory option. With the redesigned HVAC case, there is no longer a cavity for the filter. The GM parts catalog indicates there is a replacement filter available; however, there is no provision for it.
HARRYRB
I would like to replace the air cabin filter. Where & how do I remove the old one?
Feb 12, 2019 at 4:21 AM (Merged)
SERVICE WRITER
  • 9,123 POSTS
You need to access it from the passenger area of the dash. IF you open the glove and press in on the left you can pull the glove comparment away to access the tab the arrow is pointing at, release it.
https://images.2carpros.com/forum/automotive_pictures/30961_tah2_1.jpg
Under the dash there will be 4 screws that hol a panel up. remove and lower the panel. The tab you released has a small bolt in it toward the back, remove it and lower that piece (#1 on 1st drawing) that the tab is attached to. Pull down on the filter and put the new one in. reassemble
https://images.2carpros.com/forum/automotive_pictures/30961_tah1_1.jpg
