Air blowing hot after compressor is good
201,000 MILES • 5.7L • 4WD • AUTOMATIC
REBECCABISHOP
Air blowing hot after compressor is good. right level of Freon in. all blend doors and actuators doors working. what else can i check to see why still blowing hot air?
Oct 4, 2019 at 5:18 AM
Good afternoon,
Can you give me the high and low side pressures while the A/C is on?
Is the compressor engaged when the A/C is on?
I attached a wiring diagram for you to view.
Apr 23, 2021 at 2:43 AM
Good afternoon,
