What can I check or do to get heat from both driver and passenger sides? Thank you
Nov 12, 2019 at 9:31 AM
✓Experienced Mechanic
Hi:
I need to confirm something. Are you getting cold air from the passenger side or is there no air flow? I ask because it is either a mode door actuator or a blend air door actuator and I don't want to give you the wrong information.
