Air only blows on setting number four
200,000 MILES • V6 • 4WD
24GMILLAN
Air does not blow when placed on setting 1, 2 and 3 only 4.
Jul 17, 2018 at 8:42 AM
Good evening.
It sounds like the blower resistor is defective. That is what controls the blower speeds.
1. Disconnect the electrical connector from the blower motor resistor.
imageZoom/Print
2. Remove the blower motor resistor screws from the HVAC module.
3. Remove the blower motor resistor from the HVAC module.
Jul 17, 2018 at 9:04 AM
24GMILLAN
I have not checked that out yet. But now I have a bigger problem.
Jul 25, 2018 at 10:18 AM
Okay, what is the problem?
Jul 25, 2018 at 10:20 AM
24GMILLAN
Was on freeway going sixty five mph car just powered off. Once stopped I waited about half an hour since it was 104° outside. Tried and would not start so I had it towed. Next day checked my fuses and the fuse for fuel pump was blown. But forgot to mention my AC light kept blinking off and on. Not sure if that had anything to do with it.
Jul 25, 2018 at 11:06 AM
24GMILLAN
I changed the fuse and started back up. I drove it again trying to put AC on but this time just blew hot air and about ten minutes later my car powered off again on the freeway. Check the fuses and fuel pump fuse was blown again.
Jul 25, 2018 at 11:08 AM
It sounds like you may have a failed or shorted fuel pump. You will need to have it checked to confirm. It may be seizing up when it gets hot.
I would start there and have it checked.
As far as the AC, you will need to start by checking to see if there is any Freon in the system by doing a pressure test.
Jul 25, 2018 at 7:17 PM
