After replacing the clock spring the Airbag light is still on?
2009 HYUNDAI SANTA FE
194,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
STOCKMAN28659
Replaced my clock spring. Now all steering controls work but the airbag light is still on.
May 29, 2023 at 7:01 AM
CARADIODOC
  • 34,383 POSTS
Very often the diagnostic fault codes have to be erased with a scanner. At the risk of causing other problems, you can try disconnecting the negative battery cable for a few minutes. If the warning light still turns on, there's either another code that needs to be read, or you'll need to have a mechanic erase the previous code(s).
May 29, 2023 at 10:14 AM
