airbag light on?
5,500 MILES • 5.0L • V8 • 2WD • MANUAL
BALTRAVENS
All I did to my car was replace the existing OEM black leather seats to a set of brown Oem leather seats and now my SRS light is on and will not go out?
Sep 6, 2018 at 3:11 AM
  • 31,937 POSTS
Have you done a code clear? If the ignition was on with the seats out, this will set a fault code and once it is cleared it should be okay.
This video will show us how.
https://youtu.be/gnSGfEqrf_w
Sep 6, 2018 at 10:04 AM
BALTRAVENS
Okay, I just bought a “CReader 6011” and was able to clear all the codes except for 1: B00A0, “occupant classification system”.
I somehow have to do a “OCSM calibration”
Any idea how I can do that on my Mustang?
Thanks
Sep 8, 2018 at 4:44 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Apparently you have to use a diagnostic scan tool capable of doing the OCS Reset (Ford Factory Scanner). Basically after seat repair/removal that function is to zero the weight of the seat assembly after re-installation. Hope this helps and thanks for using 2CarPros.
Danny-
Sep 8, 2018 at 3:38 PM
  • 31,937 POSTS
Yes, I agree with Danny, a Ford factory scanner will be required.
Sep 8, 2018 at 9:17 PM
BALTRAVENS
Thanks.
Sep 8, 2018 at 10:10 PM
DANNY L
  • 5,648 POSTS
You are welcome!
Thanks for using 2CarPros.
Sep 8, 2018 at 10:51 PM
JESUSARENA1997
  • 11 POSTS
I have a 1997 mustang gt with 70,000 miles recently my air bag light started flashing it flashes in this sequence when i start the car flashes 7 times then stops then flashes 3 times then stops and starts again with 7 then 3 times, what does this code mean??
Jul 24, 2020 at 4:08 AM (Merged)
MERLIN2021
  • 17,250 POSTS
I will look it up when I get to my computer.
MERLIN2021
  • 17,250 POSTS
I will suggest you get a scan with a tool that reads c codes my sheet shows 53 as the highest number.
JPARENT707
I have a 95 mustang, 3.8L V6. The air bag light on dash is (what I believe) blinking "32", check engine light is on and cooling fan isn't kicking on unless I turn A/C on. I don't know if any of these have anything to do w eachother, but was hoping someone can steer me in the right direction. Thank you, Jeanine
IMPALASS
  • 3,112 POSTS
Hello Jeanine
Great job providing information. Many times we don’t get the info we need.
Some may be connected. As for the check engine light, for free you can go to AutoZone or O’Reilly’s and ask them to check your codes and then make sure you get the exact number and let us know. This is a starting point for the fan.
On your air bag, I have attached what it should be doing during initial self-check. On your code, if you are correct on it being 35, that means low resistance or short in passenger side air bag circuit.
My suggestion here is first let’s clear the code and see if it returns. I have attached how to clear the codes also.
FHENRIQUE
Dear Friends, I´m Fabio, from Brazil, I have one Mustang v6 3.8 year 1995.
My car lose battery power some days ago. I got my another car and used a boostle cable to start mustang, after started, the car show me airbag light on, I check in another websites on internet and find this light informs me code 12. in the same site they informed to replace the fuse nº4 in fuse´s box inside the car and after do it, reset the airbag module inside gloove compartment, but my problem is :
when replace the 10ah fuse for a new one, this blows instantly as i put into fuse box. how to do now ?, i can not go to next steps to reset the module if fuse always blowing ?
anybody had this experience before to help me solve this problem?
I´d like say thanks for all in advance
Fabio
you need to find out all on that circuit and trace the wiring to each component to find the failure
FHENRIQUE
do you think this shocking is from the Air Bag Module ? do you have a way to test this one ?
TKS
Fabio
CHAWLEY
'93 Ford Mustang GT, w/ 63k miles on a 302. The light for my air bag keeps flashing. What does that mean? :?
RUDPRO
  • 224 POSTS
It's should be flashing a code, like 3 flashes pause, 5 flashes pause or whatever it is. You should take it to a dealer to get it fixed. You can also reset it and see if it comes back on. Let me know if you want the procedure.
