air bag light flashing
120,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
LEN23
  • 19 POSTS
Air bag light flashing code 32. is this a faulty or dirty steering wheel clock-spring or a loose connection?
Feb 22, 2017 at 7:46 AM
CARADIODOC
  • 34,415 POSTS
It does refer to the initiator circuit, which includes the clock spring. The clock spring is the best suspect, but if the ribbon cable is breaking apart, you should lose the horn too, plus the cruise control if its switches are on the steering wheel.
Feb 22, 2017 at 8:24 AM
LEN23
  • 19 POSTS
Horn still works not sure on the cruise control.
Feb 22, 2017 at 8:52 AM
CARADIODOC
  • 34,415 POSTS
The circuits rarely all fail at the same time, but when more than one fails, that is the clue to suspect the clock spring.
Feb 22, 2017 at 9:43 AM
