Check engine light and multiple warning lights turned on
1999 CHRYSLER LHS
185,000 MILES • 2.6L • 6 CYL • 2WD • AUTOMATIC
MANUREHAPPENS
I had left the car idling with air on fan not quite on high while I checked something in the barn, I was going to take longer than I thought so I shut the car off. When I restarted the car all of these problems started happening. Airbag light, check engine light, multiple lights, air/heat fan wont work, windows wont work. Heated seats quit heating January 2020. Seat controls still work.
I just had a new starter, valve cover gaskets done, spark plugs, one rocker arm assembly replaced, and the oil sensor replaced. Last year I replaced the ignition control nodule in the steering column replaced until I found it was the starter that needed done. Starter has been replaced two times now.
I know I need to replace the front rotors and put new brake pads on because of the way it behaves when stopping.
Jun 7, 2020 at 6:12 AM
Good afternoon,
Can you give me the codes stored for the check engine light?
Is the battery fully charged? Low voltage will cause all these issues.
Jun 7, 2020 at 6:33 AM
MANUREHAPPENS
Did that reply come through?
Jun 7, 2020 at 6:45 AM
MANUREHAPPENS
Evidently not. I'll get codes for it sometime later this week as it is haying season here and I must make hay while the sun shines.
Jun 7, 2020 at 6:46 AM
Okay, sounds good. I will be here when you return.
Jun 7, 2020 at 7:01 AM
