AIR BAG
2,300,000 MILES • 1.2L • V8 • AWD • MANUAL
NAIEF NATOUR
Two lamps red and yellow airbag always on. I tried everything. I took out the fuse. Social detours. How to facilities and turn off the lights?
Which device APP recommend OBD car?
send to Email\ naiefn@gmail.com
Jun 15, 2016 at 2:55 AM
CARADIODOC
  • 34,414 POSTS
The warning lights means the computer detected an electrical problem, turned the system off, set a diagnostic fault code, and turned the lights on to tell you. The place to start is by having the diagnostic fault codes read and recorded. Those will indicate the circuit that needs further diagnosis. You will not fix anything by removing the fuses or disconnecting the battery. All that will do is potentially erase the fault codes. If this is an intermittent problem, you'll lose that valuable information if you erase the codes before they're read.
Jun 15, 2016 at 1:36 PM
