Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercedes Benz
CLK320
Warning Lights
Airbag Light
Airbag SRS light on
2004 MERCEDES BENZ CLK320
172,000 MILES
JUAN GARCIA
MEMBER
Appears SRS light. I changed the turn light switch and then appeared.
Jul 18, 2018 at 2:13 PM
Experienced Mechanic
This happens when you do not get the electrical connectors on the airbag correctly. Here is a guide to help you see what the problem is:
https://www.2carpros.com/articles/air-bag-removal-steering-wheel
Once the connectors are on the system should reset but if not. Here is a video showing you how to clear the codes:
https://youtu.be/gnSGfEqrf_w
Cheers, Ken
Jul 20, 2018 at 4:08 AM
JUAN GARCIA
MEMBER
Thank you. I going to check again the points you said, and let you know.
Jul 20, 2018 at 3:23 PM
Please do. ;)
Jul 21, 2018 at 6:33 AM
Add image or video
Ask a new question
Engine won't start
Transmission — Not Shifting
