Air and heat will not blow out in the back, but front is fine?
210,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MSLESLIE02
The air and heat won’t blow out in the back of the truck. The front is working fine.
Jul 16, 2022 at 11:37 PM
  • 55,554 POSTS
This happens when the rear blower motor goes out, but to be sure we should check the fuses (rear HVAC 30 amp) in the interior fuse panel. If it's okay, here are the instructions on how to change the blower motor out in the diagrams below:
Jul 17, 2022 at 4:54 AM
