Aftermarket radio display not working properly
260,000 MILES • 0.7L • 3 CYL • 2WD • AUTOMATIC
LOOKINGFOR
Aftermarket radio display only comes on when the weather is really cold for a certain period then shuts off. When it is hot out the display doesn’t come on. What could be the problem?
Jan 30, 2019 at 8:57 PM
KENW1
  • 213 POSTS
Thanks for visiting 2CarPros.
This is most likely due to what's called a "cold solder joint" in the display. This is a solder joint that is imperfect and makes poor contact. Temperature changes cause expansion and contraction affecting the joint. The solution is to disassemble and resolder the circuit board connections. I suggest contacting the manufacturer and having them recommend one of their repair facilities. This repair usually runs $50.00 to $100.00.
Jan 31, 2019 at 7:47 AM
