Starting issue after installing aftermarket security system
177,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
BADMAN71
How do I remove an aftermarket security system from my car listed above (EX model). Had a bad battery changed it out a few days later now the aftermarket security system will not let me start the car.
Jan 14, 2018 at 10:08 PM
STEVE W.
  • 15,416 POSTS
Well you need to have the instructions that were used to install that system. Then reverse the process. What does the not car do? Will not turn over? Turns over but does not start?
Jan 14, 2018 at 11:46 PM
