Aftermarket radio and amp will not turn on
2004 PONTIAC GRAND AM
174,000 MILES • 2WD • AUTOMATIC
DXMN
had the whole system running fine for about a year. battery dies charge it reconnect battery car starts.. no radio power or amp power.
Jan 14, 2020 at 4:01 AM
SCGRANTURISMO
  • 4,897 POSTS
Check the fuse that's in the back of the stereo. It's possible that the fuse has come loose. If it is blown then that is a separate problem that can be dealt with then. Please check the fuse and get back to. We can go from there if needed.
Thanks,
Alex
2CarPros
Jan 14, 2020 at 12:58 PM
DXMN
All fuses looked good. To be honest I do not know how the battery died in the first place my lights are auto. Thanks for the help.
Jan 15, 2020 at 2:01 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Okay, you might want to check the antennae wire. A lot of aftermarket stereos use the antennae wire as a ground for the stereo. Also check the power and ground wires to the stereo and report back with what you find out.
Thanks,
Alex
2CarPros
Jan 15, 2020 at 9:13 AM
