Aftermarket intake
310,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
DALTONTROTTER
  • 9 POSTS
I have a 2004 5.3 and I installed a acesefi aftermarket intake and I’m not sure if I need to do anything about my map sensor since my old intake had one but this one doesn’t.
Nov 26, 2025 at 8:26 AM
STEVE W.
  • 15,394 POSTS
It needs the sensor to calculate the fuel flow based on the pressure and vacuum in the intake. You will need to figure out a way to mount it into the new intake unless you have added a custom tune that eliminates it. Most of the aftermarket intakes have ports where you can tap the vacuum the MAP needs.
Nov 26, 2025 at 1:48 PM
