After replacing handle, lost control of passenger window
2010 FORD FUSION
100,000 MILES
TUBEGEEK
  • 37 POSTS
Passenger side interior handle cracked. Removed and replaced the handle.
The passenger side power window switch will run the passenger's window up and down. The driver's side power window switch for the passenger window, only works down, will not run it up. The driver's side switches work okay on the other 3 windows.
Any suggestions for troubleshooting and repair? Should I do a Power Window Reset procedure or is it a wire harness issue?
Sep 20, 2021 at 1:25 AM
SQM
  • 6,383 POSTS
This could be due to a wiring issue. However it will probably be a good idea to do the relearn process and see it that takes care of it.
I have attached the window motor reset and wiring schematics for your reference.
Sep 20, 2021 at 2:16 AM
TUBEGEEK
  • 37 POSTS
Thank you. I'l give the reset process a try first. I can do that without opening the door panel.
Sep 20, 2021 at 2:22 AM
SQM
  • 6,383 POSTS
Sounds good. Let me know how it turns out.
Sep 20, 2021 at 2:26 AM
TUBEGEEK
  • 37 POSTS
I will. By the way; the car has one bumper sticker on it. It says "SQM" (from Squam Lake, NH.) What are the odds?
Sep 20, 2021 at 2:29 AM
SQM
  • 6,383 POSTS
That's funny. But no relation. I just searched it, looks like a nice place to visit.
SQMotorsports was my shop name.
Sep 20, 2021 at 2:44 AM
