After replacing camshaft car will only run if you push the gas
2003 HONDA CIVIC
136,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
HONDAGIRL79
Replaced camshaft (exhaust) now it will not stay running. Checked the timing everything looks good. Cylinders two and three are covered in carbon, one and four covered with fuel and clean. Any ideas?
Oct 2, 2018 at 12:19 PM
Good morning,
Did this issue happen prior to the repair?
Did you check the actual compression?
It does sound like timing.
Can you verify the engine? I do not see the 2.0 in 2003.
Oct 2, 2018 at 10:47 PM
HONDAGIRL79
Thank you for the reply. Yeah it is a Civic Si hatchback k2083. Timing appears perfect, the car was fine before I replaced the cam. I have not compression but I will after work. Thanks again
Oct 3, 2018 at 3:28 AM
HONDAGIRL79
There is zero compression on cylinders one and four. Any ideas?
Oct 3, 2018 at 8:27 AM
Hello again.
There is valve damage inside the motor if you have 0 compression.
The cylinder head will have to be removed and inspected for damage. The valves will most likely need to be replaced and the pistons inspected to be sure they are not damaged.
This will be an expensive repair. you will need to make a decision of whether it is worth repairing this engine or replacing it.
Oct 3, 2018 at 7:28 PM
