After removal of a remote start it will not start
123,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
MATTCAREY1655
  • 25 POSTS
I would like to not get into why i removed the remote start, but that is all I have done, hopefully in completion but i cannot get the truck to start. It has been sitting for now over 8 months I would say. The original remote start was stolen out of my garage along with a lot of other things so i can't even just reinstall. But shouldn't it be able to be started with the key or what is going on here? I appreciate your help as always.
Apr 19, 2022 at 9:23 AM
  • 110,248 POSTS
Was the remote start an original equipment part or was it something that was installed aftermarket?
Also, what happens when you turn the key? Does the starter engage, and the engine not start or does the starter do nothing?
Let me know. Also, I really need to know what all has been worked on as far as the electronics.
Apr 19, 2022 at 11:20 AM
MATTCAREY1655
  • 25 POSTS
It was aftermarket but i believe dealer installed. All I've done was clean up the whole harness for the vehicle. replaced a few grounds that were rusted out, and was attempting on removing remote start completely so you would think it would still start with factory key still? Everything is put back together to the best of my knowledge I didn't get too deep. But definitely had a mess on my hands. When i turn the key the message center lights up, i believe dome lights come on etc. Keep in mind i do have the hood open too. I probably should close it. I don't know. I don't know where to turn but me and my girl have this vehicle paid off and summer is starting. Three kids. She works a lot and that's been rough. Finding rides for 8 months when She has always taken truck or had me to take her in. it's parked where i parked it. Runs great and now, ugh. I hear some clicks under the hood when i turn the key other than that just silence. headlights and everything seem to work with key in and on.
Apr 20, 2022 at 2:58 AM
MATTCAREY1655
  • 25 POSTS
I think I'm going out in a few here, I'll tell you exactly what happens. One moment here.
  • 110,248 POSTS
Do me a favor. Check to see if the clicks you hear are coming from the relay box or the starter. Let me know.
Apr 20, 2022 at 1:01 PM
MATTCAREY1655
  • 25 POSTS
From the relays in the TIPM I would say. I'm working alone here so bear with me. Sorry. But it really, I think, would sound more like its coming from underneath if it was the starter, it sounds higher and closer to me than that.
Apr 21, 2022 at 11:56 PM
MATTCAREY1655
  • 25 POSTS
Also. Just thought you may like to know this also. I tested the battery voltage as it sits, 12.8v. More than sufficient to start, correct? Just so I know I'm good there?
Apr 21, 2022 at 11:58 PM
  • 110,248 POSTS
Regardless of the battery voltage, if there is a weak connection, it can cause this. By chance, could you get a helper to turn the key to start while you check for voltage at the smaller wire on the starter motor?
Apr 22, 2022 at 11:24 AM
MATTCAREY1655
  • 25 POSTS
Yes, I will. I'll be in touch soon. Thanks
Apr 22, 2022 at 1:49 PM
