after oil got in my firing chamber I melted two of the sparking end off my plugs what is the major engine damage
2008 SAAB 9-3
99,000 MILES • 2.0L • 4 CYL • FWD
JROD716
Mar 27, 2016 at 8:06 AM
HMAC300
  • 48,601 POSTS
it cold be tulipping of valves, detonation of pistons in engine etc. best to find a small camera to look inside and do a compression test. it may have done pre ignition/detonation that can happen and burn a hole in piston as well as burn the sides of the pistons and damage the walls which would require an overhaul. but if you can find a camera that can go down plug hole lot easier than doing a teardown.
Mar 27, 2016 at 9:13 AM
