Engine overheating
1999 TOYOTA LAND CRUISER PRADO
400,000 MILES • 3.0L • 4 CYL • AUTOMATIC
JIM COYLE
After new radiator engine overheated, replaced with 140,000 second hand one. Towing boat had same over heating issues.
Apr 12, 2018 at 3:30 AM
  • 31,937 POSTS
thermostat was changed in the replacement engine? water pump ok? cooling fans working? no transmission codes?
Apr 13, 2018 at 11:21 PM
MIKE H R
  • 3,094 POSTS
Towing anything can be a strain on a engine and transmission, If you go up hills with towing the boat use a lower gear so the engine does not work as hard, When you put a new radiator in did you change the thermastat. Some mechanics advise to change it when ever you drain coolant out of the engine and radiator,,
Apr 13, 2018 at 11:26 PM
