After lock cylinder replacement, do I need to program new keys or just replace the microchip from the old keys to new keys?
16,000 MILES
ANNIELU
My car key will not turn inside the key slot. When I insert the key, the immobilizer recognizes the key, but the ignition lock cylinder has some glitches to it that makes my key not turntable. So, I am planning to replace the ignition lock cylinder. The new ignition lock cylinder comes with two keys. If after replacing the cylinder, I can mechanically turn with the new keys, but I won’t be able to start the car because the immobilizer doesn’t recognize the new key. In that case, do I need to program my new key to match with the immobilizer? Or I can avoid this hassle by just carrying my old key around because it has the microchip that communicates with the immobilizer.
Jul 3, 2023 at 10:18 AM
  • 55,686 POSTS
I would try some wd40 in the keyhole first. Also, if the key is recognized by the immobilizer, then just have the key with you. This guide may help you and I have included the ignition lock replacement instructions as well.
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Check out the images (below). Please let us know how it goes
Jul 4, 2023 at 5:09 AM
