After the car is warmed up starts missing then stalls
2008 SUBARU LEGACY
115,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
DJKLEIN
  • 16 POSTS
The car starts fine then when it is warm it starts to miss a little then a lot until it stalls. New throttle body, spark plugs MAF, MAP, fuel pump and filter, EGR, purge solenoid, PCV and hose, new coil and wires etc. I'm ready to get a new brake booster and injectors. Three shops have tried and failed.
Apr 30, 2022 at 11:32 AM
  • 110,244 POSTS
Has anyone checked the crankshaft position sensor? When they begin to fail, oftentimes, they will fail when they get hot. Once they cool, they work again for a bit of time, and then the same thing happens.
Take a look through this link and let me know if you feel it mirrors what you experience:
If it does, you can check if the RPM signal is lost during cranking when it won't start. Or you can check to see if the spark plugs lose spark. Here is a link that explains how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
If you find that there is no spark or no RPM signal, here is a link that explains in general how to replace the sensor:
I attached the directions below specific to your vehicle.
Apr 30, 2022 at 3:46 PM
DJKLEIN
  • 16 POSTS
No, but this makes perfect sense. The crank sensor, I thought about this, I'll check.
Apr 30, 2022 at 11:10 PM
  • 110,244 POSTS
If you can, let me know what you find. I have a feeling this is where the problem is coming from and am interested in knowing.
May 1, 2022 at 11:40 AM
DJKLEIN
  • 16 POSTS
I got the sensor and after 1/2 hour it starts stumbling until it stalls. David
May 19, 2022 at 8:11 AM
  • 110,244 POSTS
By chance, do you have a live data scan tool? Also, is the check engine light staying on while it runs?
Let me know and let me know if you checked for codes.
May 19, 2022 at 12:50 PM
DJKLEIN
  • 16 POSTS
Good Morning,
I do have a hand live data tool. The first code I got in the past was P0171. We did that round and replaced bank 1 and 3 injectors and most of the parts listed above this email then P0420 came up. Found a hole in the cat and replaced the pipe along with both 02's. Then P0457 came up and replaced the evap canister in the back panel. Then I found you online and I hope you can help me with this never-ending problem. Thank you, David
May 19, 2022 at 6:34 PM
DJKLEIN
  • 16 POSTS
The check engine light in all cases did stay on until I got rid of them. They did not come back.
May 19, 2022 at 6:37 PM
DJKLEIN
  • 16 POSTS
We replaced the crank sensor. I think this thing has Cam sensors too. Just to throw this on the table?
May 19, 2022 at 6:53 PM
  • 110,244 POSTS
You are correct, it does have a cam sensor. See pics 1 and 2 below. So, if I understand, each time you got a code, it was repaired by replacing the component. Are there any codes at this point?
Do me a favor. Using the scanner, check the short-term fuel trims and when the engine is cold, check what the ECT is signaling. If the vehicle is cold, it should be close to ambient temperature.
When you check the fuel trims, the engine will need to be at operating temperature.
May 20, 2022 at 2:21 PM
DJKLEIN
  • 16 POSTS
Bear with me, I'm helping my 85 year. old mom. My friend has a better scanner to look at this. Thank you, David
May 20, 2022 at 11:53 PM
DJKLEIN
  • 16 POSTS
Hi, a friend brought over his computer with a data cable and we data-logged from a cold start to when the car started stumbling and stalled.
We have the data-log file if you want it, just tell us how to send it to you.
In the meantime, here are the data points you requested:
Cold start
AFR Learn #1 = 0.00 (on 2nd new O2 sensor)
AFR Corr #1 = 0.00
AFR Learn #3 = -53.00 (on 2nd new O2 sensor - suspect short in wiring harness? )
AFR Corr #3 = 0.00
Engine Coolant Temp = 53 degrees
Intake Air Temp = 83 degrees
Ambient Air Temp = 73 degrees
Engine RPM = 1324
Operating temperature
AFR Sensor #1 = 14.70
AFR Learn #1 = 14.02
AFR Corr #1 = 2.54
AFR Learn #3 = -51.00
AFR Corr #3 = 0.00 (the ECU is not adding correction to the learned value)
Engine Coolant Temp = 192 degrees
Intake Air Temp = 104 degrees
Engine RPM = 710 to 730
The engine started stumbling after 20 minutes of running time, we had to add throttle up to 1,500 RPMs before the stumble stopped completely. The ECU was adjusting the Throttle Angle to compensate and try to stabilize the idle.
Thank you for your help.
Dave Klein
May 21, 2022 at 2:45 AM
  • 110,244 POSTS
The air/fuel ratios look good. You want it to be around 14.7:1. By any chance, do you also have the short-term fuel trims? That will help me identify if the computer is compensating.
Also, if you could record it and upload it for me to hear, it may help.
May 22, 2022 at 12:35 PM
DJKLEIN
  • 16 POSTS
AFR Corr #1 = 2.54
AFR Learn #3 = -51.00 (that is negative 51.00)
AFR is short term fuel trim I believe.
May 25, 2022 at 5:37 AM
  • 110,244 POSTS
Here is my confusion. AFR stands for air/fuel ratio. That is what the O2 sensors are indicating. Fuel trims are what the computer is doing to reach a target ratio.
ARF Learn #3 is interesting. If that was the fuel trim, it would indicate the engine is running extremely rich and the Corr (if that is a correction) wouldn't be 0.
Something isn't adding up. Are you noticing any smoke from the exhaust, specifically dark gray or black?
May 25, 2022 at 11:43 AM
DJKLEIN
  • 16 POSTS
Good morning, I Googled is ARF the same as short-term fuel trims? I found it to be true. My friend and I disconnected the downstream O2 and connected the old O2 and left it on top of the air cleaner in the air not connected to the engine. The ARF stayed at Negative 51. When we gassed it, it moved to negative 63 then kind of stayed there. Shortly after the car stumbled then stalled again. The downstream was not connected.
I did not notice any smoke from the exhaust, specifically dark gray or black.
May 31, 2022 at 12:42 AM
  • 110,244 POSTS
Is it AFR or ARF?
If you have a negative 51, the computer is trying to lean the fuel mixture. At this point, we need to check fuel pressure and how quickly the fuel pressure is dropping off.
Fuel pressure drop (in this case) could indicate leaking fuel injectors causing the engine to run rich. Here is a link that explains how it's done:
Most parts stores will lend you a fuel pressure gauge if you need one.
Also, I listed the directions specific to your vehicle which include fuel pressure specifications below.
Let me know what you find or if you have already done this.
May 31, 2022 at 1:11 PM
DJKLEIN
  • 16 POSTS
Hi Joe,
I checked the fuel pressure. At start I have 50.7 to 51.4. Good. When warmed up and beginning to stall it is 50.8 to 51.3. I have a window in the fuel tester and was looking for bubbles. No bubbles. Thank you, David
Jun 14, 2022 at 3:45 AM
  • 110,244 POSTS
Hi David,
The fuel pressure is nearly perfect. Have any of the codes returned? Also, by chance do you have a voltmeter gauge in the vehicle or is it a light?
I think it's time to look at other possible issues. For example, low voltage. Let me know if you have a gauge or light in the vehicle.
Next, I have to ask, has the P0420 returned? Is there any ticking or anything you can think of? Also, have there been any codes related to the cam sensors?
Jun 14, 2022 at 1:33 PM
DJKLEIN
  • 16 POSTS
Top of the day to you, I have a voltmeter gauge. P0420 has not come back yet. Ticking from the injectors but, that's normal. No cam sensor codes. I did not replace the cam sensor.
Jun 15, 2022 at 6:16 AM
  • 110,244 POSTS
When the vehicle is warmed up and starts having issues, I need you to check the voltage at the battery. Basically, we are testing to confirm the alternator is doing its job.
Here is a link that explains how to test an alternator:
Let me know what you find. Also, let me know if you have a live data scan tool. If you do, when you start to notice the misfire, check the short-term fuel trims, and let me know what they are.
Jun 15, 2022 at 3:00 PM
DJKLEIN
  • 16 POSTS
Good eve,
The alternator is at 14.10 volts running. When it starts to stall it goes down to 13.04 after the stumble happens. Not before. Good.
2.51 short-term fuel trims # 1 upstream. Short-term fuel trims negative 51 downstream.
Thank you, David
Jun 17, 2022 at 6:54 AM
  • 110,244 POSTS
The negative 51 indicates the computer is trying to lean the fuel mixture. On your scanner, does that indicate -51%?
Jun 17, 2022 at 12:23 PM
DJKLEIN
  • 16 POSTS
Yes, it does, very weird huh.
Thank you, David
Jun 18, 2022 at 10:20 PM
  • 110,244 POSTS
David, if the fuel pressure was consistent, you likely have a leaking fuel injector. When you checked the fuel pressure, how quickly did the pressure drop off when you turned the key off?
Let me know,
Jun 19, 2022 at 12:26 PM
DJKLEIN
  • 16 POSTS
Hi Joe,
The pressure dropped off slowly when I turned the key off. I replaced all four injectors and still had the same problem. Maybe computer or wiring?
Thank you, David
Jun 26, 2022 at 5:50 AM
  • 110,244 POSTS
If everything checks out good, it has to be a wiring issue or PCM. Check the wiring at the coils, PCM, and anything that could affect the engine. With metal connectors, heat causes them to expand. Maybe you are losing a good connection. However, I would think that would set a code.
When the engine is warm, start wiggling wires around the PCM, coils, and injectors and see if anything changes. Also, I know the crank sensor is new but double-check that connection.
Jun 26, 2022 at 2:15 PM
