After ABS light goes out, but pedal still vibrating when braking
99,700 MILES • 4WD • AUTOMATIC
JMF2020
The brake pedal is still vibrating after the light is gone off. Had brakes repaired, ABS light went out. However,still have the vibrating in my pedal when I brake.
What does this mean?
Mar 5, 2021 at 9:11 AM
  • 110,248 POSTS
If you still feel the abs engaging, chances are you have a bad wheel speed sensor. If the sensor is sending a signal, even if it is wrong, the light will stay out. The computer doesn't know if the sensor is accurate. It accepts the signal.
Here is what I suggest. There are wheel speed sensors at the wheels that can be checked. You will need a digital multimeter (DMM) to check. Here is a link that explains how it is done:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
If you look at pic 1 below, I highlighted the sensors. These are located behind the wheels and will be mounted in the steering knuckle in front and hub assembly in the rear.
____________________________________
Take care and God Bless,
Mar 5, 2021 at 2:21 PM
