After a mild accident my vehicle will not start
500 MILES • AUTOMATIC
BENKLETUS OMURUKPA
I hit another car from the back while on like 40. I tried starting but couldn't. A mechanic came and tried but said it was an electrical problem, so I called an electrician who came and said it was the starting sensor. We've tried different sensors but non has worked so far. I'm confused and don't know what to do again. Please help
Apr 6, 2020 at 7:47 PM
Good morning,
What exact sensor have you replaced?
Can you hear the fuel pump run when you turn the key to on?
Can you check for spark?
Apr 6, 2020 at 8:48 PM
BENKLETUS OMURUKPA
Yes, I can hear the fuel pump run when I turn the key to on.
And it sparks.
Apr 10, 2020 at 11:36 AM
Okay, you need to check the actual pressure to be sure there is enough pressure.
When you crank the engine, do you get an RPM reading on the tachometer on the dash.
Apr 10, 2020 at 11:40 AM
BENKLETUS OMURUKPA
Okay. I'd do that and get back to you. Thanks, cheers.
Apr 10, 2020 at 11:44 AM
You are welcome.
Always glad to help.
Apr 10, 2020 at 11:46 AM
