Cranking but not starting
150,000 MILES • V8 • 2WD • AUTOMATIC
BILLANDSONYA TERRY
My old car was firing but not starting. I replaced the fuel pump and it cranked and ran better than it has in months. A day or two later I tried to crank it and it acted like it was not getting gas . I pulled the gas line to the carburetor off and it is definitely getting gas from the fuel pump into the carburetor. It will fire when I prime it with gas into the carburetor but otherwise will not crank. Still acts like it is not getting gas. Thanks
Oct 23, 2018 at 2:18 AM
Good morning.
What carburetor do you have? Did you replace the fuel filter in the carburetor?
I do not have any pictures of the old carburetors. If you could upload a picture of the carburetor, it would help.
Oct 23, 2018 at 2:33 AM
BILLANDSONYA TERRY
Hey Roy, I replaced the fuel filter in the carburetor and it cranked right up and ran. Thanks so much for the information. Now I have a small leak of gas coming from where the fuel line goes into the carburetor. I am going to put some pipe tape on that and see if it stops it. Thanks a lot. Bill
Oct 23, 2018 at 5:52 AM
You are welcome.
There is a thin washer on the filter adapter. Make sure it is there as that is usually the reason for the leak.
Oct 23, 2018 at 6:22 AM
BILLANDSONYA TERRY
Will do, thanks Roy.
Oct 23, 2018 at 6:29 AM
You are welcome.
Glad to help.
Oct 23, 2018 at 6:34 AM
BILLANDSONYA TERRY
I rechecked that washer and re-positioned it. Looks to have fixed the problem. Thanks again. I cannot wait until something else goes wrong so that I can get your advice, LOL. Bill
Oct 23, 2018 at 6:56 AM
Sounds good.
Oct 23, 2018 at 7:22 AM
