Cheers, Ken
Feb 5, 2018 at 3:03 AM
BECKY PASQUINUCCI
MEMBER
Another question, l had the motor mounts replaced.when l picked up the truck the ABS and advtrac light was on. I have never had had it on before. l ask the mechanic why was it on and all he could say was l do not know. Do you think perhaps when they changed the motor mounts they inadvertently messed something up?
Feb 5, 2018 at 3:54 AM
✓Experienced Mechanic
Yep, the wiring for the ABS wheel sensors runs near where they were working so I would look in the front for either wiring damage or a disconnected sensor.
If you run the codes it should tell us exactly which side it is.
