Advice Required Regarding Intermittent Warning Sound at Highway Speeds?
1.8L • AUTOMATIC
MOHANBARATHI
  • 8 POSTS
I bought this used car two years ago and recently noticed a strange warning sound with unusual behavior.
A few months ago, while driving at around 120 km/h, I heard a warning sound that stopped when I reduced the speed below 120 km/h. I initially assumed it was a speed-limit warning that had been set previously.
However, last week, the same warning sound occurred at around 100 km/h. Since the speed was different from the previous occurrence, I suspected that it might not be a speed-limit warning and decided to investigate further.
I noticed that the warning does not occur immediately after starting the car. Instead, it appears only after driving for approximately 30–40 minutes on the highway. The sequence is usually as follows:
* The warning sound first appears when the speed reaches around 100 km/h. It stops when the speed is reduced and I brought it down to around 60 or 40 km/h.
* After driving for a few more minutes, the warning appears again at around 90 km/h and stops when the speed is reduced.
* After another few minutes, it appears again at around 80 km/h and similarly stops when the speed is reduced.
* If I maintain the speed without slowing down, the warning sound continues continuously until the speed is reduced.
Interestingly, after the car has cooled down, the warning does not occur. For example, when I drive the next day, I can drive for several hours in the city even at speeds approximately 100 km/h without hearing the warning.
The issue seems to occur only after the car has been driven for around 30–40 minutes on the highway. Once the car reaches approximately 100–120 km/h, the above sequence starts again.
I am also sharing two audio files containing the warning sound:
* First audio file (7 seconds): The warning starts at approximately the 3-second mark and lasts for about one second. This occurred when I briefly reached 100 km/h and immediately reduced my speed.
* Second audio file (17 seconds): The warning starts at approximately the 3-second mark. This occurred when I reached 90 km/h. This time, I reduced the speed gradually so that the warning could be heard clearly. The sound continues until approximately the 16-second mark, when it stops after the speed is reduced to around 80 km/h.
I would appreciate your advice on what could be causing this behavior and what I should check.
SKM
Sep 17, 2026 at 11:02 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
First identify the vehicle's exact model, market and any aftermarket alarm, navigation or driver-warning equipment. Compare the sound with the applicable owner manual and have the shop listen to the original recordings. Establish whether it is an electronic chime or a mechanical noise before ordering parts. Ask for a scan of the relevant body and instrument systems as well as the engine. Record the operating conditions without handling a phone or scanner while driving; do not deliberately repeat high-speed runs to provoke an unidentified warning. Stop safely if it accompanies overheating, an oil-pressure warning, abnormal braking or a change in vehicle control. Identifying where the sound comes from is a practical first step. The absence of codes alone does not establish that the vehicle is safe or that a warning setting is responsible.
Guidance references and applicability
Toyota: Owner manuals https://www.toyota.com/owners/warranty-owners-manuals/ Official US manual locator. Obtain the manual for the vehicle's actual market and equipment if it is an imported model. The sound has not been identified from a recording.
Read the replies · Discussion summary and reported outcome
MECHTRIX
  • 547 POSTS
When you hear the warning sound its coused by a few things like for instance the abs system or the srs system and a few more they sound any time fluid pressure gets low or things over heat and a few other things but there's really about 5 that would do that after driving a while but theyre always accompanied by a light on the dash like a check engine light an oil light or maintainance required light tpms light abs light srs light and so on ..if it happens again look at the dash to see if there are any lights on that weren't there
before .. if you see one on youl notice that when the sound stops the light might go out also but not always ...now that said" .. the vary best way to find out whats causing the issue is with a scan tool it should pin point the system where the problem accured and show a code that was cast at the time it happened and point you in the right direction to make the repair ..best of luck hope this helps.
Sep 17, 2026 at 9:36 PM
MOHANBARATHI
  • 8 POSTS
Thank you for taking the time to reply and for your suggestions.
I missed mentioning that I had already checked the dashboard whenever the warning sound occurred. There was no warning light at any point; the dashboard remained completely normal.
I also forgot to mention that I have already had the car checked with a scan tool at two different local garages under normal conditions. No fault codes were found, and everything appeared normal.
Since the warning occurs only after driving for some time at highway speeds, I have not yet been able to perform a scan while the warning is actually occurring.
One more question: Have you heard this particular alarm sound before on a Toyota vehicle, and if so, do you know what specific warning or condition this sound is normally associated with?
Thank you again for your advice. I really appreciate your help.
Best regards,
SKM
Sep 17, 2026 at 10:33 PM
MECHTRIX
  • 547 POSTS
Yes its more comon than you might think and it can be triggered by any of the things i meantiined in my reply above ...that said If you dont see any indication light on the dash when the alarm sounds off than if you want to get to the bottom of the problem its gonna take a better scan tool one thats comparable to a factory Toyota scan tool like the dealers use it needs to be a bi directional tool so it can comunicate better with the computer in your car and really go deep to find out whats really going on since your not getting any codes thats about all you have at this point ..if you know a shop near you that has a good quality scan tool that can give you a full scan and a full health report that would be the way to go ..good luck hope this helps
Sep 18, 2026 at 8:53 PM
MECHTRIX
  • 547 POSTS
Just a side note usually if theres anything serious youl almost always get trouble codes so the cars probably ok to drive for now while youre trying to figure it out since you haven't retrieved any codes...for what its worth hope this helps
Sep 18, 2026 at 8:59 PM
Discussion summary
The owner described a warning-like sound after extended highway driving, recurring at progressively lower speeds and stopping when speed decreased. No dashboard warning was observed, and two garage scans found no codes. The owner mentioned recordings, but those recordings were not available for this review.
Reported outcome: The sound was not identified and no repair was reported.
The recordings, market specification and warning-system equipment were not verified. A factory speed warning, aftermarket device or mechanical noise remains unconfirmed.
Read the original discussion
