Clutch adjustment
200,000 MILES • 1.9L • 6 CYL • 2WD • MANUAL
TOM321
Clutch pedal goes to the floor.
Nov 26, 2018 at 2:13 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny,
It sounds like you are having a problem with the Clutch Slave Cylinder. It is a cylinder used hydraulically to engage the clutch. I have attached a tutorial showing how to replace. After replacement the system will need to be bled. I have also attached a tutorial showing that as well. Hope this helps and feel free to ask any questions if needed. Thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/throw-out-bearing-replacement
ttps://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Nov 26, 2018 at 2:26 PM
