After replacing coolant code p0420 appeared and will not start
207,000 MILES • V8 • 4WD • AUTOMATIC
APARTON2018
Replaced the coolant and now vehicle will not start but cranks. Error code p0420 is read. Replaced both battery and alternator, belts and A/C. pump a week ago.
Jun 20, 2018 at 2:17 AM
Good evening.
Why did you change the coolant?
420 is a code for a bad catalytic converter. The precious metals inside are worn out. It needs to be replaced.
Did you check for spark?
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Jun 20, 2018 at 11:15 AM
