After replacing coolant code P0420 appeared and will not start
APARTON2018
  • 2002 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 207,000 MILES
Replaced the coolant and now vehicle will not start but cranks. Error code p0420 is read. Replaced both battery and alternator, belts and A/C. Pump a week ago.
Wednesday, June 20th, 2018 AT 9:17 AM
  • 52,797 POSTS
Good evening.
Why did you change the coolant?
420 is a code for a bad catalytic converter. The precious metals inside are worn out. It needs to be replaced.
Did you check for spark?
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Wednesday, June 20th, 2018 AT 6:15 PM
