Adding volume control to steering wheel
184,000 MILES • 2.0L • 2WD • AUTOMATIC
ARUNJADHAV
Connect after market wires to newly installed steering wheel control.
Jul 16, 2019 at 11:26 AM
Hi Arunjadhav,
What exactly is the issue? Did you install it and it is not working? IF so, can you attach the wiring diagram and switch detail that was provided with this aftermarket kit? Clearly, using OEM wiring diagrams will not help if it was not installed on the car originally. We will need to see what you are working with and what the issue is in order to try and figure out what the issue is. Thanks
Jul 17, 2019 at 7:31 AM
