1994 Acura Vigor Lights Dim
CORHOLS7781
I just bought a 1994 Acura Vigor (manual trans). This car has a pro-lock alarm system. I replaced the battery and terminals (the whole ground wire and the terminal connection on the positive) because the old one was severely coroded. Now every time I turn on the headlights, parking lights, hit the brakes (tail lights), and even hit the power locks, all of the other electrical (radio, interior lights, even engine especially with the bright lights on-it almost stalls) gets really dim (the radio even shuts off with the lights on). I have voltage checked the battery with the car on and off and it reads in regulations. I've also checked everything I can see and nothing (that I changed or repaired) seems to be grounding out or anything. I can't get a chilton repair manual for another week (it's on order) and I've only had the car for 5 days! Please someone give me some kind of good news!? :cry:
Oct 4, 2007 at 12:39 PM
FISHERMAN
  • 937 POSTS
[quote:bfc56fc4f3="corhols7781"]I just bought a 1994 Acura Vigor (manual trans). This car has a pro-lock alarm system. I replaced the battery and terminals (the whole ground wire and the terminal connection on the positive) because the old one was severely coroded. Now every time I turn on the headlights, parking lights, hit the brakes (tail lights), and even hit the power locks, all of the other electrical (radio, interior lights, even engine especially with the bright lights on-it almost stalls) gets really dim (the radio even shuts off with the lights on). I have voltage checked the battery with the car on and off and it reads in regulations. I've also checked everything I can see and nothing (that I changed or repaired) seems to be grounding out or anything. I can't get a chilton repair manual for another week (it's on order) and I've only had the car for 5 days! Please someone give me some kind of good news!? :cry:[/quote:bfc56fc4f3]
Make really sure that the ground (-) its making good solid contact with the frame....
I`m almost positive that`s the problem..
also check the ground to the engine....
check it good!
those simptoms are weak ground...
let us know!
Oct 4, 2007 at 1:14 PM
CORHOLS7781
I really do appreciate that, I had it grounded to the engine but forgot to ground that wire also to the frame. That fixed it right up! Let me know if you need anything! Thanks! :D
Oct 5, 2007 at 5:42 AM
FISHERMAN
  • 937 POSTS
[quote:ac7f829b33="corhols7781"]I really do appreciate that, I had it grounded to the engine but forgot to ground that wire also to the frame. That fixed it right up! Let me know if you need anything! Thanks! :D[/quote:ac7f829b33]
It`s Fixed ?? That sounds Great!!!
If we need something??
To be Honest... If you can donate something to our forum and leave feedback for me I`ll do appreciate that!
(if possible) If not... don`t worry!
we still helping you and everyone the best way we can!!
Thanks and best regards!
:D
Oct 5, 2007 at 6:35 AM
Suggested Repair
Ensure the battery negative cable has a solid ground to both the engine and the vehicle frame. A missing frame ground caused the voltage drop when lights and accessories were used.
Conversation Summary
The owner of a 1994 Acura Vigor reported dimming lights, radio shutoff, and near-stalling when headlights, parking lights, brakes, or power locks were used after replacing a corroded battery and terminals. Battery voltage tested normal. The expert advised verifying solid negative ground contact to the frame and engine. The owner had grounded only to the engine; adding the frame ground fixed the problem.
